How to read Serial Data from Arduino using labview VISA?
hi
i need one way communication. hence i'm going to do is i write the code in arduino program. Then going to use labVIEW visa for making the SCADA system. I have go through several examples but i could not find a example of working with multiple I/O devices. In my projects it is using 10 LM35 and 4 GHT11 modules with 5 switches. any one can give me a sujestions email me
kasunjithamila@gmail.com
Message 61 of 143
(5,001 Views)
hi
Sir, i am student of third year electronics I'm assigned to a project in dht22 arduine interface with LabVIEW sensor .. most of the things I did .. but now the matter is that I am able to read un Humidity + Temperature separately how do I split the data up. I am sending serial data from Arduino to LabVIEW . .. The two files ( prog and arduino Labview file) I am sending you please solve my problem and send me the updated file ..
will be free for you
Thank you
Message 62 of 143
(4,898 Views)
Your attachment is missing.
Message 63 of 143
(4,895 Views)
hi
Thank you
Message 64 of 143
(4,887 Views)
hi saifullah92mh
thank you for the comment you have post and i have already finish the work using visa read and write and also using the arduino serial read and write
i will post my project after it is 100% complete
Message 65 of 143
(4,883 Views)
@saifullah92mhr wrote:
hi
Thank you
What's the format of the data you are sending from the Arduino?
Message 66 of 143
(4,869 Views)
data format is in decimal you can check out from the output of arduino...
Message 67 of 143
(4,852 Views)
That doesn't answer my question at all.  Be very specific in what your data frame looks like when you send it from your Arduino.  ASCII data that looks like a number in text?  Binary data?  How are you separating your data points?  Is there a termination character?
Message 68 of 143
(4,843 Views)
Thank you so much CarlosOtiniano for this example read_serie_monitor.vi ‏18 KB. in my case, im reading three valus from arduino, ex. 12.00,13.00,45.00, do you knaow how to modfiy this code to get the three reading. you help is indeed apreciated
Message 70 of 143
(4,055 Views)
