How to read a status message from one vi and display in another vi
Here ya go Raj, 8.5.
Richard
Message 11 of 18
(1,484 Views)
PaulG. wrote:
Can we give negative Kudos? Smiley Wink
  • Totally unecessary.
  • Just trying to help.
  • No good deed goes unpunished.
  • etc.
  • etc.
  • WHAT, exactly, is complictaed about THIS?? Especiially compared to setting up/wiring queues or two action engines. I'd say this is less compicated. There may be a performance hit, maybe a mS, but this is the neatest way to update front panel stuff inside a sub-VI, and has been recommended / demoed to me by NI.
Richard
Message 12 of 18
(1,478 Views)
Broken arrow it is working fine what ever you suggested. Thank you very much.
I have one more doubt, to update latest status message keeping the old one i am using following. Is it OK? will affect my program execution or speed?
Rajashekar
Message 13 of 18
(1,453 Views)
here is the one i am using to update the status
Message 14 of 18
(1,451 Views)
Message Edited by bla457645 on 10-14-2009 06:24 AM
Message 15 of 18
(1,440 Views)
The way you have it there Raj, your message will look like this (where "Your_Status" is the Status message)..
Your_Status
Operation 1 Your_Status
Operation 1
... probably not what you want?
Richard
Message 16 of 18
(1,428 Views)
Probably my way is...
i will be using sequence structures in a subvi, in which in each sequence i will be performing certain operation which i need to display that operation in the status message without overwriting.
Like my status indicator will be
Operation 1 performing
Operation 2 peforming
Operation 3 performing
checking for the results
storing the results
The above information i want to display in status indicator, in which each message will be in each sequence.
Rajashekar
Message 17 of 18
(1,425 Views)
i will be using sequence structures in a subvi....
Well, one of your problems (a big one) is relying on Sequence Structures in general.
I have attached another example, this one uses Queues. You should find what you need in the message sending routine, but according to your response, I think you need to study/read about LabVIEW program flow.
Richard
Message 18 of 18
(1,422 Views)
