How to read all the files in the directory
I want to read all the files from a directory and perform some operations on them. How to read one file at a time from the directory. Is there any operation like the * sign in Dos and Matlab. Is there any such vi which does that.
Nitin
(3,465 Views)
You can just use the "List Directory" function in the File->Advanced File Functions palette to get an array of filenames and then do what you need.
(3,459 Views)
And if you need a recursive list of the files/folders in a directory, you can use the Recursive File List.vi, found in vi.lib\utility\libraryn.llb.  This VI ships with LabVIEW 7.0 and later.
-D
(3,449 Views)
Hi Darren, the VI you suggested indeed does the job and I was impressed with the way it avoids using recursive calls by reference node. I have been trying to do the same thing using recursion and in spite of all efforts, never quite got it to work. After I read your hint I just felt some grudge, as I am a user od LV 6i and had to go out to find a comp with LV7 installed:-). However, good advice, I thank you!
(3,390 Views)
I'm glad I could help, Danny.  Using the VI Server technique for recursion is very slow and memory-intensive.  I have never seen a need for recursion in LabVIEW that couldn't be solved with a loop and shift registers.
-D
(3,385 Views)
Here is an old thread that used a queue to do a recursive file list.
(3,376 Views)
