How to read and write hex command to an instrument through a serial port
RS 232 communication with hex command
(2,819 Views)
I am not sure about your question.
An Hex command is nothing but a string with chars that are not always alphanumerics (under $20). To write/display such a string in LV, just right click the string control, then select "Hex display". Another way of manipulating such strings is the "\ code display" option, where control chars appear as \i chars.
Hope this helps !
If you have other problems with serial port communication don't hesitate to ask.
Chilly Charly    (aka CC)
(2,819 Views)
Helped me out of a similar situation, thanks!
(2,819 Views)
chilly charly wrote in news:506500000005000000F2D60100-
1079395200000@exchange.ni.com:
> Hope this helps !
> hesitate to ask.
And if the data exist as U8 array (array with unsigned 8 bit numbers) use
the "String To Byte Array" function.
Rolf
(2,819 Views)
