How to read and write same .DAT file using different VIs(one to write and another to read) without data loss
I'm writing .DAT file with the help of VI on PC and I want to read the same file in another VI running on another PC without any error and data loss. Please help.
(2,124 Views)
Hi Govindparab,
a "DAT file" has no meaning to us…
You need to implement a VI, which is able to read your "DAT file" and run that on your other computer…
As you didn't provide any substantial information you need to implement it on your own!
(2,115 Views)
The first thing that comes to mind is a Sharing Violation but all is not lost...
You will probably have better luck reading the target file and writing a temporary file, then when you are done. Close the file you had open for reading and copy the temporary file over the original file you read.
=== Engineer Ambiguously ===
(2,065 Views)
