How to read array on text file
Now, i have text file and it 's contained 3 columns  1000 rows (i save this data from signals to text file ). I want to read this data
from current text file (.txt) but, only 1st colums 1000 rows . How to fix this problem, please help me.Smiley Sad i have some example about my text file
Message 1 of 9
(5,042 Views)
Message 2 of 9
(5,033 Views)
Just use the "read from spreadsheet file" function have a look at the existing VIs :
Help >> Find Example >> and search for "spreadsheet" there are different VI that can inspire you 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 3 of 9
(5,026 Views)
Thank you,Smiley Wink but i have one problem : i want to sparate  2 D array becomes 1 D array , How can i do this .
Message 4 of 9
(5,027 Views)
How do you want to do that ?
If you have 3 lines and 3 columns you want only 1 column of 9 ? If yes, there is a function "reshape array that do this very well 😉
Epictetus
Antoine Chalons
Message 5 of 9
(5,019 Views)
What do you mean with "separate 2D array becomes 1D array"? Could you be a bit more precisely?
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 6 of 9
(5,019 Views)
Now, i try to use this (untitled.vi). You can see 2 D array that is the output from the spreadsheet to array
but right now,  I want to use only 1D array because i will use DBL data type. Please help me Smiley Sad
Thank you very much.
Message 7 of 9
(5,015 Views)
Use the "Index Array" function to select the necessary data. There you can define where the data is taken from (row and/or column as parameter).
Using LV8.0
Message 8 of 9
(5,010 Views)
Yes, I already success. Thank you Very Much Smiley Very Happy Thank you  Thank you  Thank you .
Message 9 of 9
(4,998 Views)
