How to read continue binary string
I have a encoder and it send me a continue string in ASCII. The port configuration is : 1 start bit, 7 data bits, 1 parity bit, 2 stop bits and termination character = x0D . And, the code is like this :
ASCII code 31 (011 0001) = SB 1000 110 PB SB SB
My problem is I can not cut the string at the good place.
Thank you for your help.
Message 1 of 10
(4,850 Views)
How do you want to split the string?  Have you tried using the Match Pattern function from the String palette?
-Khalid
Message Edited by Khalid on 08-10-2005 01:30 PM
Message 2 of 10
(4,840 Views)
I try to find how take the data between two termination characters. And the bit are reversed and I want put these in right sense.
Thank.
Message 3 of 10
(4,833 Views)
To find the termination characters, there are a number of vi's available to use such as "Search and Replace String", "Search/Split String", or "Search and Replace Pattern" as those all return an offest number where it has found the termination character.
In order to reverse the sense (with the possibility of having 15 people find more efficient ways to do this like yesterday), use "String to Byte Array", then "Reverse 1D Array", then "Byte Array to String", and your data will be reversed.
Message 4 of 10
(4,825 Views)
Thank you, but I receive always the same error : framing error. Do you know what is this ?
Message 5 of 10
(4,818 Views)
Ummm it could depend on a number of things..  It would be easier to diagnose if we could see your code...  image or vi.
Message 6 of 10
(4,813 Views)
I thing I have a problem with the code send by the encoder. There is in LIFO for each 4 bits and I thing that the port receive in FIFO, do you know if this can be one of my problem ?
Message 7 of 10
(4,807 Views)
Where exactly -- which VI -- do you get this "framing" error?
-Khalid
Message 8 of 10
(4,800 Views)
The framing error occur with only in VI contain Visa configure serial port plug on Visa read.
Message 9 of 10
(4,792 Views)
You will want to narrow down the issue.  First make sure you are actually able to read the values into LabVIEW.  Don't worry about the format, just make sure you are reading the value without any errors.
Next, take the read value and parse it out the way you want.  For this part, in fact, you can play with your own test strings.
Hope this helps.
-Khalid
Message 10 of 10
(4,777 Views)
