How to read individual elements from FPGA read write control?
 I want to perform a read operation with FPGA read write control. In my FPGA code there is a read operation using FPGA io node, the data thus obtained is stored in a cluster in FPGA vi. In my host code, i want to read that cluster elements individually. How can i implement it in the FPGA read write control???
(2,967 Views)
If your FPGA vi has a cluster on the front panel and you want to read from that cluster in your host vi (using read/write node) then you can ether read all elements of the cluster or individual elements.
Message Edited by StevenA on 06-26-2008 11:02 AM
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(2,954 Views)
Thanks Steven. Can you tell me whether i can connect this individual cluster elements which is a fixed point number acquired from an io module in my case, to a waveform chart?
(2,933 Views)
Yes, that's no problem.  When you wire it to the chart, Labview will automatically convert the fixed point type to a double.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(2,931 Views)
