How to read io using a .lib file, how to load the .lib file, how to see the io
It’s ultimately allocated with the system allocater but that does not mean that your DLL function could do a free or realloc on that pointer address as it is not the actual start of the memory buffer but at some offset in a larger memory buffer.
Even if it would, it’s still not safe to use C library memory allocation functions since your DLL linked in C runtime library may be a different one than what LabVIEW was linked with and they work on entirely different memory heaps.
Rolf Kalbermatter  My Blog
Message 11 of 11
(196 Views)
