How to read multi frame CAN message with NI USB-8473
using USB-8473 to test automotive electrical products: with commands to read serial number from UUT, the expect answer is 28 bytes serial number in format as below:
TX: 03 22 XX XX 00 00 00 00
RX: 10 21 62 XX XX 31 32 33
TX: 30 00 14 00 00 00 00 00
RX: 21 34 35 36 37 38 39 30
RX: 22 31 32 33 34 35 36 37
RX: 23 38 39 30 31 32 33 34
RX: 24 35 36 37 38 00 00 00
now the issue is, most of time I only received three frame as show in underline, but cannot received the last frame.
my question is the issue relate to CAN card USB-8473 or the LabVIEW code (show in below)?
BTW, all the frame can read with NI PXI CAN card and CANoe device.
your help is well appreciated!
thanks!
"I think therefore I am"
(3,614 Views)
hi can i have a copy of .vi? Thanks
(2,475 Views)
