How to read multiple channels of Keithley 2700 digital multimeter
Keithley channel (CH) Unit
111 vdc
112 temperature
113 vac
114 vac
115 temperature
116 temperature
117 nc
118 vdc
Note: format of "111:112:113:114:...118" does not work and i can scan two channels with the same unit at a time.
How could i scan channels with multiple units from 111 to 118 at once?
Kind regards,
Balázs
(1,824 Views)
Hi Balázs,
What does the manual of your Keithley device tell you about that?
Does the device allow such a configuration at all?
In case it allows to configure a list of channels using different measurement types: which commands do you need to use to configure such a measurement task in the Keithley?
Spoiler
In the end it boils down to "Read the fine manual!"
The Keithley can be programmed using SCPI commands: you can use all allowed commands and configure everything that is supported by the device…
(1,813 Views)
