05-18-2021 08:41 AM
| Keithley channel (CH) | Unit |
| 111 | vdc |
| 112 | temperature |
| 113 | vac |
| 114 | vac |
| 115 | temperature |
| 116 | temperature |
| 117 | nc |
| 118 | vdc |
Note: format of "111:112:113:114:...118" does not work and i can scan two channels with the same unit at a time.
How could i scan channels with multiple units from 111 to 118 at once?
Kind regards,
Balázs
05-18-2021 08:48 AM - edited 05-18-2021 08:50 AM
Hi Balázs,
What does the manual of your Keithley device tell you about that?
Does the device allow such a configuration at all?
In case it allows to configure a list of channels using different measurement types: which commands do you need to use to configure such a measurement task in the Keithley?
