How to read raw signal for spectrogram?
(3,353 Views)
Is this a LabVIEW question? If so, it should be moved to the LabVIEW forum.
Please provide much more information:
  • What kind of instrument?
  • How is it interfaced?
  • What do you mean by "raw signal"?
  • What software are you using?
(3,344 Views)
I have the same question, hope you don't mind that I hijack this thread 🙂
I just want to know how to read the raw bytes. I have attached the wav file(just rename the extension to .wav). Its at 300 baud, so each byte should be 3.33ms but its hard to know where to start and where each separation is.
I'm using Audcity to view the raw signal
Its a wav file
raw wav
Audacity
(3,277 Views)
Your picture is broken.
have you tried Sound File Open VI?
(3,271 Views)
its not a picture, its a wav file. Change the extension to wav.
The Sound File Read VI is a plugin/function in labview?
(3,258 Views)
It is a function. Did you check my link?
(3,248 Views)
