How to read serial data from a particular START value?
I want to start reading serail from particular information.Suppose I want to start after getting a particular Hex Byte combination. How to that?
(2,742 Views)
Hi Omi,
you need to differ between reading serial port and storing data.
You should read the port in a loop the whole time. But you only store the data after you received your "particular hex byte combination"...
(2,739 Views)
Ok good idea. I am new user,so how to check the particular start during write? WHich functional block to use?
(2,733 Views)
