How to read spreadsheet with different data formats
Hello Application engineers,
I would like to do a small program to process stock historical data. The data can be downloaded from yahoo finance page, for example, Microsoft stock (MSFT), see the attached data.  It has date format for the first column and prices and volume in floating format for all rest columns.
I want to use two read delimited spreadsheet VIs to read the data, one uses date format to read date and another uses floating format to read all prices and volume  data. Then I can manipulate the data in any way for subsequent data processing. However, the read VI does not work as I thought. The floating format just read the year, ignoring all other data. The date format just got zero for the first column.
Could someone help me with the reading issue?
Thanks.
(1,220 Views)
Accepted by topic author edmonton
Hi edmonton,
ReadFromSpreadsheetFile uses SpreadsheetStringToArray internally, and that functions doesn't seem to like those timestamp format specifiers…
Maybe you should compare your format string with the data formatting in your CSV file…
See this:
(1,168 Views)
(1,153 Views)
