How to read temperature data from binary file?
Is it possible to read temperature data from binary (unknown file type) like this file with LabVIEW?
(3,618 Views)
Accepted by topic author Pusak
Hi Pusak,
the general answer is NO.
In your specific case I guess you want to do this:
Is this the expected content of your data file? (Use a DBL array constant…)
(3,600 Views)
WOW! Thanks a lot GerdW.
How did you know that?
(3,591 Views)
Hi Pusak,
I know the binary format of floating point numbers…
(3,580 Views)
Here is a slightly more simple solution.
(3,569 Views)
Excellent, thanks so much!
(3,521 Views)
