How to read the actual z cursor position in a 3D surface when the x and y positions where set programmatically
I set the x and y cursor position in a 3D surface with a property node. The cursor is shown at the right new position but the z Value is not recalculated. How can I force LabVIEW to recalculate?
(3,492 Views)
Hi visablocked,
which 3D graph do you use in your application?
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(3,450 Views)
I use 3D Surface: Graph -> 3D Graph -> Surface
(3,448 Views)
Hi code-lux,
I did some research with the Surface 3D Graph. You can read or write the cursors Z position the same way you set the X and Y position. In the property node you can also select the cursors z position and read or write it. To change the access mode of a connection of the property node, right click it and select "Change to Read/Write".
I attached a screenshot, how my code looks like.
Melanie
Melanie Eisfeld
(3,439 Views)
Hi Melaniee
Thanks for your efforts. This is exactly what I have. The problem is now that the z position that you get from the property node is not the right z position for the cursor position you just set with the property node but it is the z position that corresponds to the last position set by dragging the cursor with the mouse.
I called NI support and it seems like it is not possible to use the cursor in that way. I was recommended to calculate the value from the data that is fed in to the graph. This is what I'll do.
Nevertheless all the z positions including the interpolated values are in memory for the display of the 3D surface and there should be a way to access them. Any hints how to do that are highly appreciated.
(3,422 Views)
Hi code-lux,
maybe you could try to set the initial cursor position at the start of your program to (0|0|0) via the property node. Afterwards you can continue calculating the current position of the cursor using the relative data from the property node.
Melanie
Melanie Eisfeld
(3,396 Views)
