How to read the .dat file which stored by using the Hex format ?
How to read the .dat file which using the Hex format ?
Logger2.dat is the raw data; Plot.jpg is the plot for the Logger2.dat.
thanks
(6,056 Views)
Accepted by topic author LC0815
Your file is not in HEX format (exclusively using characters 0..F and maybe delimiters)
You file seems to be mostly binary, with some header sections consisting of readable strings.
You need to know the structure of the file (header size, datatype, byte order, etc.) Do you have more information? Do you have the program that created the file?
(I am sure with some twiddling most of the data could be retrieved by trial and error ...)
(6,037 Views)
Hi altenbach
Thanks for your replying.
I have the Matlab code which can read this file, see attach.
Previous file is the High Speed Dat File.
Could you help to confirm?
thanks again
best regards
(6,012 Views)
Hi altenbach
    thanks for your reminder, you are right I can read the file now.
(5,988 Views)
