How to read the data in a txt file on a web site?
I want to extract the numbers located in txt files on a web site. It's a normal url. Not a ftp.
Does anyone know how to do it?
Message 1 of 10
(4,369 Views)
TomTurbo;
You can use the DataSockets VIs to perform what you want. The key is to use the expression [text].
If you go to my website VI Security.com and check the Products & Tools section, there is a download called VIs for random.org. Check the VI called "Check Buffer (random.org).vi". If you type the URL of your .txt file you can then extract the numbers.
Regards;
Enrique Vargas
www.visecurity.com
www.vartortech.com
Message 2 of 10
(4,369 Views)
Thanks Enrique,
I've tried it but I can't make it work.
Nothing happens
http://www2.keck.hawaii.edu/acs/fdc/FDC_K1_2004_10_17_007.txt
Tom
Message 3 of 10
(4,369 Views)
Hi Tom,
What do you want to extract from the text file??
I wanted to extract an IP address from a pearl script from my FTP server and this was the vi that I used .I dont know if you are trying to do the same?
Here is the vi.It is in LV 7.1
Hope its helps .
Good luck.
ohiofudu.
Certified LabVIEW Architect
Certified TestStand Architect
Message 4 of 10
(4,369 Views)
Thanks for answering
The web page is full of txt files that I can download manually very easy.
The files are full of measurement data which I want to process.
The VI you have attach is version 7.1 and I have 7
Tom
Message 5 of 10
(4,369 Views)
Hi Tom,
Have you tried this link:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DC0756A4E034080020E74861&p_node=DZ52000_US?
Philip C.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 6 of 10
(4,369 Views)
Tom,
Take a look at the attached VI. I am not sure how you interpret the data but this grabs the data as a 1024 by 169 array and graphs it for you.
Notice I take the URL and add [text] to retrieve the string.
Message 7 of 10
(4,369 Views)
This is exactly what I want Evan.
I'm only using the evaluation version of LabView which
seems to be 7.0 and it can not run your vi, since it 7.1.
It's really a pity since I want to see this work before I buy it.
Any idea? Could you save it as 7.0 or ?
Tom
Message 8 of 10
(4,369 Views)
Tom,
Here is the VI. If it doesn't come through, all you need is a Datasocket read, and the url is http://(your url)[text] The text portion being the key. I then just sent the response throught the spreadsheet string to array function.
Message 9 of 10
(4,369 Views)
Thank you so much Evan.
It works fine
Tom
Message 10 of 10
(4,369 Views)
