How to read *.txt file and plot the XY graph?
Hi!i have a *.txt file like the following:
1.0,2.0
1.1,2.1
1.2,2.2
How to read this file and plot it in XY graph by Labview 7.0 ?
thanks a lot!
(3,557 Views)
you can use the read from spreadsheet.vi to read the pairs. the XY graph expects an array of clusters. each cluster has 2 elements 1. the x-coord 2. the y-coord....
bundle each element (x,y) and create an array of those pairs...
Dan
p.s. if you need more help email me privately...
(3,557 Views)
thanks for your help.but when i use the "read from spreadsheet.vi",i can i can only read one colume of the file,can you give me an example vi? thanks!
(3,557 Views)
the problem is that the read from spreadsheet.vi default delimiter is a tab, your file uses comma's change the delimiter to a comma and it should work for you...
Dan
(3,557 Views)
yeah,that's the problem,i appreciate it for your help!
(3,557 Views)
(3,557 Views)
