How to read windows register entry
Hi everyone
I am currently writing a windows registry entry, using regedit, but I also needs to read back the entry to confirm that other software are not using it.
I am currently using the method to control the output file of PDF Factory.
Does anyone know how I can read the setting back from the windows registry please.
Peter Gillespie
(2,669 Views)
If you launch the example finder ("Help" > "Find examples...") and search for "registry" you'll find example VIs to Read / Write / Delete Registry entries.
Be carefull with what you do Smiley Surprised
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,665 Views)
