How to record seconds in LabVIEW and display it in Excel file
My 6 sensors' output goes to individual "Set Dynamic Data Attributes" and then from there 6 different signals go to "Write to measurement file". When I start the run, I got 6 readings in Excel but now I am missing time (in seconds). May I know how can I include time (seconds) in my coding so that the time display in an Excel file?
Thank you!
(1,396 Views)
Thank you!
A picture of 7 express vis gives us nowhere near enough information to help you.  We simply cannot see any of the evil express vi configurations.
Attach your vi or a snippet created by selecting the all of the express vis and "Create snippet from Selection" under the Edit Menu.
(1,371 Views)
"Write to measurement file" has options for a time column (default is empty). What are your settings there?
Any why are you bothering with excel? Would be so much easier to stream to a tab delimited text file after writing the headers once.
(1,367 Views)
<Age Shaming Mode>
How to teach an old dog a new trick.
"CA, TDMS...TDMS...TDMS...HERE! like THIS! TDMS."
"That's it CA, GOOD CLA!" Gives CA Kudos...
"TDMS, CA , TDMS!" Gives Kudos
</Age Shaming mode>
(1,355 Views)
Well, they could just keep everything "as is" and generate a time scalar, give it a name attribute ("time") and build it into dynamic data to be merged with the dynamic data from the other 6 data points. Cringeworthy!
(1,342 Views)
No CA, TDMS!  (no Kudos)
(1,336 Views)
Obviously they want Excel, so why change the topic?
(Unless you are also talking about the excel plugin) 😄
(1,333 Views)
