Look in the Time and Dialog palette and grab a "Wait (ms)" function and drop one in each loop. Then wire a time delay to these. This will put a time delay in each loop that you specify.
You'll probably have to experiment a bit to figure out how fast each loop
needs to run. With no delay in the loops, they will run as fast as your processor can handle, which could be 10s of thousands of times per second. Drop an indicator on the iteration terminal in one of your loops and let it run for a couple seconds and you'll see what I mean. Plus with no timing in the loops, they will not run at a steady rate as they fight for processor time (also appearent when you watch the iteration counter, it jumps)
A time delay will give your system time to do othe
r tasks and will make the loops run at a steady rate. It can be as small as 1 ms, but it's not likely that you need it run that fast.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
