How to reduce the execution time of the VI while parsing data from the XML file
Based on this example shows to read and process the two attributes. In my case, I have to read and process with more than 10 attributes.
Message 11 of 21
(1,436 Views)
So? Is that a problem?
Certified LabVIEW Architect
Message 12 of 21
(1,429 Views)
As per my XML file attributes, I tried to read the first two attributes with the help of the example I could not able to get the output.don't know what was going wrong. As per the example in the query string, I have specified two attributes as per my XML file and run the code received length of the output zero if I mention only one value in the query string only one output I can. help me to get 1set of data output as per my XML file.
Message 13 of 21
(1,416 Views)
Some code would be useful...
Message 14 of 21
(1,409 Views)
I have one doubt about using LIBXML.
As per my XML file, Each set(query name(SDI Name, SDI, SSM Name, etc..)) of data having a set of signals ( Start bit, End bit, Etc.). 1st of data having two sets of Data value but the signal of both data are same.  for example (  Data 1 set of signals 12, Data 1.2 set of signals 12) I want to update the value 12 for each data but I get to update as 24 data on each data. Please help me here.
Message 15 of 21
(1,375 Views)
As requested before, show us the code you have with valid example data. Your explanation makes not much sense to me and I have better things to do than trying to rebuild everything from scratch to try out what your problem might be.
Rolf Kalbermatter  My Blog
Message 16 of 21
(1,368 Views)
Code attached. XML file I have already attached in this conversation thread.
Message 17 of 21
(1,359 Views)
Any update on this ?.
Message 18 of 21
(1,334 Views)
We where all under the impression that you have enough information to get this working.
Are there still problems you are facing? Post what you have.
You have managed to build the old solution, the new solution won't be more difficult.
Creating the entire solution for you starts to look an awful lot like work. We are all helping out people by answering questions online for free, but we do have our own work we need to do to get paid.
Message 19 of 21
(1,322 Views)
Hi
I have build the code which way I wanted to read the XML file by using LibXML and the code attached previous thread.
I had some doubts about my code so only I have requested here.
Thanks for your support.
Message 20 of 21
(1,316 Views)
