How to register a dll written in LV?
Hi LV'ers,
I have written a simple dll in labview and I am trying to register it using regsvr32.  I get the following error message:
"Test was loaded, but the  DllRegisterServer entrypoint was not found.
Test does not apppear to be a .DLL or .OCX file"
(Test is the name of the dll I created).
Is it possible to create labview dll's that can be registered in this way?
I have attached my example code (LV7) ....
mr_e_cat
(2,406 Views)
Why are your trying to run regsvr32? You normally use this to register OLE or ActiveX controls and a LabVIEW dll is neither.
(2,397 Views)
