How to register an dynamic event for/with NI-Scope?
I know how to do that for example for DAQmx  to get a DONE event.
Now I tried that with NI-Scope but no luck
example with refnum , broken wire with the Scope.instrument-handle 😞
Greetings from Germany
Henrik
LV since v3.1
(2,218 Views)
Accepted by topic author Henrik_Volkers
The short answer is: Sorry, you can't.  The NI-SCOPE refnum does not support any driver-dispatched LabVIEW events in the way that the DAQmx refnum does.
However, if you call NI-SCOPE fetch, that function call will block until the necessary samples have been acquired, which may be sufficient flow control.  Otherwise, you can poll the niScope Acquisition Status.vi in a while loop until it returns a non-zero result or errors (see attached snippet).
(2,138 Views)
Thank you balexand for confirming.
I wrote an idea on that one ..
I have a solution, however using dynamic events would have been more elegant...
Henrik
LV since v3.1
(2,123 Views)
