How to register an event for LV event structure from WinApi "PostMessage"?
Hello experts,
I'm using a standard cardreader (RS232/USB) which I access via the manufacturer's API, this works fine so far. However I don't want to poll the status of the reader all the time. The cardreader sends windows messages using the WIN API "PostMessage" as soon as there is a status change (insert card into reader, reader disconnect etc.)
Now how can I use this fact to get an event for my event structure? Any ideas?
Thank you
Melanie
(3,476 Views)
hello Melanie,
This may be tricky but you could use the Windows Message Queue Library example to get the messages from the USB drivers;
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E7AC56A4E034080020E74861&p_node=DZ52071&p_submitted=N&p_rank=&p_answer=&p_source=External
And from then create a custom user event based on the POSTMESSAGES received;
Hope this helps,
Cyril Bouton
Active LabVIEW Developper
(3,467 Views)
If you're working with the windows API, you can use the getmessage function from user32.dll to read the message from the queue. Theoretically, The code I'm posting should work, but I haven't tested it. Also, If it does work, I think it will grab all the messages from the window. You can use this as your event (the function should wait until it gets a message) or you can use it to fire a dynamic event.
___________________
Try to take over the world!
(3,455 Views)
Here's the code.
___________________
(3,453 Views)
Wrong !
You can't use "GetMessage" to steal messages from another window. It's not that simple.
As Cyril Bouton pointed out, the way to intercept messages from another window is demonstrated in the message queue example.
George Zou
http://gtoolbox.yeah.net
George Zou
(3,433 Views)
Why both of your links point to the sample example ?
I've seen this example long long time ago. It demonstrates how to intercept window messages,
but it doesn't show you how to convert an occurrence to LV event (although it's simple).
George Zou
George Zou
(3,426 Views)
Sorry.
Like I said, I didn't have time to test the code. This is actually an adaptation of a code that worked perfectly for me on a PocketPC emulator window, which I put together quickly, of the top of my head, without much thought or checking.
___________________
(3,413 Views)
