How to relate temperature to voltage change
I was basically wondering how I would be able to set up a program to watch a temperature change from a change in voltage.  The reason that there is a -1 voltage leaving the program is due to the fact that I needed to shut down a function generator, which required a -1 Volt peak to peak to be send to the Input section of the generator.  What I need from this program is a way to see a temperature change when a voltage changes.  The temperature reading must be in a numerical valve and represent the temparture of a certain water tank from a thermistor.  The thermistor changes resistance, which can be converted into a change in voltage, thus all i need from Labview is to set off an alarm at 45 degrees and also to show the temparture valve.
(3,204 Views)
I don't recall where I got the coefficients used in this VI, I am using them on a Quality Thermistor #QT06002-343.  It is a fairly standard 10Kohm NTC thermistor.
Jim
LV 2020
(3,197 Views)
first off thanks for you help.  I am  not sure where i would insert the thermistor on the Elvis board?
(3,183 Views)
Hi KP2008,
could you please stick with just one thread?
(3,177 Views)
You're welcome.  I'm afraid I haven't met Elvis Smiley Very Happy or his board, so I can't help you there.
Jim
LV 2020
(3,161 Views)
