How to release license seat after LabVIEW crashes?
I use my User-Based license on 2 machines. Yesterday, I had to End Task LabVIEW on one of those. Now the license is stuck with Network Checkout for that computer, even when LabVIEW isn't running.
Opening & closing LabVIEW on the offending machine didn't release the license.
Removing & adding the license server on the offending machine didn't release the license.
Restarting the offending machine didn't release the license.
How do I fix this?
Message 1 of 8
(3,935 Views)
When you open LV, are there 1 or 2 seats checked out?
Did you change any settings in license manager?
Message 2 of 8
(3,883 Views)
Your VLA admin will be able to help.  The problem is on the server side.
Message 3 of 8
(3,871 Views)
Accepted by JÞB
Thanks for the replies. Our admin needed to restart the license server service to release the seat.
Message 4 of 8
(3,838 Views)
Don't forget to mark Jeff's post as the solution so other people can know the problem was resolved and benefit from your knowledge.  🙂
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(3,825 Views)
Actually,  the OP filled in what the VLA Admin needed to do.   So, super powers activated and solution marked.
Now I know what the admin needs to do 😄
Message 6 of 8
(3,812 Views)
All right, so you get a kudo, then, for pointing the OP in the right direction.  🙂
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(3,807 Views)
I'll take the kudos but, since the OP had already tried everything client side, there was only one place left to look:D. Simple logic.
Message 8 of 8
(3,781 Views)
