How to release memory?
I do a IrDA communication test. Two USB IrDA in one computer. I program the communication test by NI IrDA modules. Search  --> find? --> communicate --> release. The process will repeat 5000. The error info occured about 1500. Error infor as following:
Error 61 occurred at IrDA Open Connection in IrDA_Comm_Test_060726.vi->IrDA_A_05.vi
Possible reason(s):
LabVIEW:  Serial port parity error.
LabVIEW:  The system could not allocate the necessary memory.
How to reallocate the necessary memory for IrDA module by LabVIEW(7.1)?
Thank you!
(3,460 Views)
We need to see your code. Are you using build array inside your loop??
http://zone.ni.com/devzone/conceptd.nsf/webmain/979f737147fd5c01862569f300638674
(3,452 Views)
do you close all that open connections properly? Is there really no parity error?
(3,451 Views)
Thank you Gerdw! I setup two link. One is server, the other is client. I only closed the server's source and forgot to close client's source. I programed a test vi. It's better then only close server's source.
Thank you unclebump! I'll try your advice late.
(3,418 Views)
