How to relink logs?
As i move one project in labview signal express to a new computer it s a number of logs that are misslinked in the project. "the project that you just opened contains logs which are linked to the following deleted files. you need to restore these files in order for this project to work correctly"
Solution?
(3,037 Views)
Hi ahnberg,
Do you have the original log files? Could you possibly provide a screenshot of the files that are missing? It maybe that re-creating the directory structure in exactly the same manner will  fix this issue.
Andrew McLennan
(3,010 Views)
