How to remove border of front panel when vi is running?
How can I run a vi front panel without its gray border?
Or how can I color the front panel's border black so as to run it on a computer desktop whose color is black?
In the attached vi written in labview8.6, I would like to run a vi and display a picture, a checkerboard for instance, without the white border of the vi.
I hope not to have to size the vi to a size larger than the size of the monitor as I would like to move the vi's front panel to different to different positions on the monitor.
Rob
(6,072 Views)
Ur vi is not in LV8.6...
(6,053 Views)
Accepted by topic author errante
In the VI Properties "Window Appearance" category, go to Customize.
In the Customize Window Appearance, uncheck allow user to resize window. Hope it helps.
(6,024 Views)
NintinD.
Perfect!!!  I wish I had posted my question before I spent so much time on failed attempts.
Thank You!
Rob
(6,012 Views)
