How to remove elements of an array based on this index A+i*B order
Let's say I have 36 elements in my array and I would like to delete elements 10,11 and also 10+i*12 and 11+i*12
I mean for example  10,11,22,23, 34 and 35  when i starts from 0 to 3
What is the simplest way to implement this
(2,974 Views)
You'll need a For Loop.  You'll need a shift register to maintain the array between iterations as you proceed to delete each element.
I'd recommend deleting the last elements first because if you delete an earlier element, all of the index values of the later elements will shift forward by 1.
(2,965 Views)
This code actually conditionally (re)builds the resulting array rather than deleting elements, which provides the same effect.
Feel free. Contact me for anything more,
    Pang
You too can be LabVIEW Awesome!
(2,956 Views)
