How to remove learning path from learner dashboard?
Good afternoon everyone,
do you know how I can remove learning path from my learner dashboard or if it is possible? I clicked on some course to see the description and they were automatically added to the learning path, and now I don't know how i can remove they.
(1,902 Views)
Accepted by topic author Domodo
Hello Domodo,
It will get listed under " My Learnings" and there are no option to remove from your list.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,853 Views)
