How to remove or delete line in a string indicator?
I have a string indicator that receives data continuously. If the number of lines in the indicator becomes 100 then on receiving a new line after 100th line the very 1st line will be removed and so on..in simple words i need to maintain only the latest/last 100 lines received in the indicator. How would i do this? Kindly help me out.
(4,294 Views)
hi Arvinth,
  Just a simple,after number of lines >100,then assing local variable of string to empty string and continue...
Thanks and regards,
srikrishnaNF
Srikrishna
(4,290 Views)
Hi SriKrishna,
I have few questions,
how do i find the number of lines in a string indicator? is there any property or do we need to create a design to find out the count of lines with the help of end of line constant?
Also when the number of lines becomes 100, on receiving a new line only the 1st line has to be deleted/removed not all the lines. 100+1 - 1st line =100
100+2 - 1st & 2nd line = 100 etc...
Latest 100 lines have to be maintained on the display.
Thanks for your time,
Arvinth
(4,281 Views)
Accepted by topic author Mr.7
HI
Please find the snapshot attached.
Hope this helps
Regards
Santosh
(4,272 Views)
Thankyou very much Santosh.
Arvinth
(4,264 Views)
