How to remove picture from button (typedef)
years ago i created a costomized button which is now a TypeDef.
There i added a picture to the "On-state".
How can i remove this imported picture to just show the color that is defined in properties?
(3,128 Views)
Accepted by topic author OnlyOne
Hello OnlyOne,
select your Control, click on Edit -> Customize Control (ot type Alt-E, E), then in the Control Editor make sure, your picture is visible, then type Ctrl+M or click on the little Button with the wrench- Symbol. Then click on the picture an hit Del.
If you can't select the picture, because it's behind some other parts, in the control editor menu go to Window -> Show Parts Window, there you can select the picture element. When the picture is selected, you have to click on the window title of the control editor, to give it the focus for the Del- keystroke.
Greets, Dave
(3,109 Views)
