How to remove the noise of the measured current
Hi everyone,
i am measuring the current value on a motherboard with my Agilent 34410A.
As you can see in the image, it seems to be present a noise on the signal.
Any suggestion for remove this noise with a filter?
(1,778 Views)
Hi Mario,
Why do you think it's noise?
Which current on which motherboard are you trying to measure?
(1,763 Views)
GerdW and
I am measuring the current on a motherboard designed by a friend of mine.
I applied the ammeter between the transformer and the motherboard in order to know the current draw.
I made a small diagram:
This noise seems to be natural oscillations of the ammeter that I even see without any load applied.
How can I remove it?
(1,730 Views)
Hi Mario,
When the ammeter shows such "noise" then you should do a (re)calibration!
(1,715 Views)
Any Variant in signal (Noise) in measurement, usually requires recalibration of an ammeter.
Should be the first step.
(1,705 Views)
Good morning,
the recalibration of the ammeter is unfortunately blocked by a unique 12-digit code from the manufacturer. It should be attached to the purchase documentation but since more than a year has passed I can't find it. I will contact the manufacturer for information.
In the meantime, thank you all.
(1,667 Views)
