How to repeat a stacked structure sequence?
I have a program that runs under a stacked structure sequence.
Now i want it to repeat to the first frame every time the sequence is over.
can this be done? how?
thanks in advance
Eyezik.
(6,402 Views)
Hi Eyezik,
use a while loop to do that. And now if you change to a loop, try to rebuild your code to a state machine architecture. If you do that, you can jump to each fram (then case) you want.
Mike
Message Edited by MikeS81 on 05-09-2008 02:47 PM
(6,398 Views)
Hi!
   simply put it inside a while loop!
   But, maybe you can provide more details, because this can be a poor technique, in some cases... perhaps you need a conditional execution?
graziano
(6,394 Views)
Great!
i put a while loop around the whole sequence and it worked like a charm.
thank you so much.
Eyezik.
(6,389 Views)
Hi Eyezik!
   A little tip, repeated in many places on this forum: when possible, avoid using stacked sequence structure, use instead flat! Stacked S hides code, and make it less readable and debuggable.  Of course, Stacked S saves space on the screen, but not always this is good, since when diagram becomes huge, it's time to modularize.  So, it's good to force ourself to code keeping "clean" block diagrams!
   Let's go further, if possible, use subVIs, in cascade, and force sequence execution with dataflow (the error out of the first subVI to the error input of the second, etc...)
graziano
PS.: this is my advice, but you'll find a reference in "the labview style book"
(6,374 Views)
I would also like to add to that. As mentioned above, if you have to repeat the stacked sequence structure, using a while loop works but it is not proper technique. Convert the code into a state machine, which is basically the same except that it uses a case structure and it allows you to control the sequence of the execution of the states. Using this architecture allows you to "modularize" your code a little better than using a stacked (of flat) sequence structure.
Eli S.
(6,340 Views)
To have better understanding about state machine architecture, read here and here.
Mathan
(6,318 Views)
