How to replace a button with icon?
Hello!
Is there a way to replace a button with an icon? Or maybe to cover the button with som picture so it looks like a icon?
In the attached file I show with a picture what I mean?
Is it possible in LabVIEW to get color in some picutre transparent? For example, I do not want the white color to be visable, can I make it transparent?
Message 1 of 11
(8,257 Views)
1. Open Help->Search the LabVIEW Bookshelf.
2. Find corresponding manual:•
LabVIEW Custom Controls, Indicators, and Type Definitions
Jack
Win XP
LabVIEW 6.1, 7.0, 7.1, LabWindows/ CVI 7.1
Let us speek Russian 🙂
Message 2 of 11
(8,245 Views)
not sure what Jack talks about but I couldn't find that anywhere ...anyone knows where can I add a custom image to an button?
Message 3 of 11
(8,012 Views)
Message 4 of 11
(8,004 Views)
            Any boolean button can be replaced by any picture by customizing that button.Right click on the boolean button select Advanced>Customize...that will open a new window with the button,copy the picture you want to replace on it and right click on it select Import picture from clipboard>True and same procedure for false condition. I have attached a vi. Hope this helps you.Let me know if this is ok.
Message 5 of 11
(7,982 Views)
thanks guys
Message 6 of 11
(7,940 Views)
Auto,
When I right click on the button in edit control screen, "import picture from clipboard" was grayed out ...would know how to enable that?  is it because I'm using v8.6?
Message 7 of 11
(7,931 Views)
That option is greyed out if there is nothing in your clipboard.
I usually open an image in paint do a ctrl-a to slect all and the a ctrl-c to copy to the clipboard.
Ben
Message 8 of 11
(7,925 Views)
You may also wish to look at this video tutorial.
Message 9 of 11
(7,909 Views)
thanks guys
Message 10 of 11
(7,897 Views)
