How to replace a sub vi that is used in many main VIs with another sub vi under a different file name without repeating the replace vi operation?
  1. Close all your VIs
  2. Open the new VI
  3. Rename it with the old name
  4. Open all your VIs using the VI to be changed
At this level, your VIs have the new VI but with the old name
  1. "Save as" the name of the new VI with the new name
  2. Close the new VI
  3. Close all the other VIs and save them
Respect exactly this procedure in the described order
It would be nice if you take the time to rate this answer
http://www.machinevision.ch
(2,437 Views)
