How to replace value in one array column based on value in second column?
Hi, I'd like to search a column in a 2D array for values that meet a certain criteria (e.g. < 0.98).  Based on which rows meet this criteria, I want to replace the values in a different column of the array (change to 'NaN' so that the values will not be included in any calculations on that column, for example the finding the mean).  I've attached a sample .csv file.  If the values in column 3 (index 2) are less than 0.980 (or some other user defined value), then the value in column 2 (index 1) should be replaced with NaN.  Can someone help out with this search and replace task?
Keith
(using LV 2009 SP1)
(4,879 Views)
You should just loop through your array.  Look at the array row by row and make the replacements as necessary.  Keep the array in a shift register.
(4,873 Views)
Ah, of course! By rows. Thanks, that's what I needed to get over my brain lock. I was stuck thinking in terms of columns and thought I would have to deal with the two number columns as separate 1D arrays. Here's what I came up with. The first column of Date/Time is split off to convert into a time stamp. Any suggestions for improvements are welcome.
22074iA325147D5665DC2F
(4,861 Views)
Accepted by topic author HawaiiKeith
Some quick hits.
You can merge the two For Loops together
You don't need the constants 1 and 2 in the index array.  They will be set automatically when you expand down the index array once you've wired in the 0 into the column index.
It seems like a lot of extra array manipulation going on unnecessarily.
See below.  I didn't try to duplicate your code to see how it actually runs, but I believe what I've attached will yield the same result with a lot fewer steps.
(4,853 Views)
Thanks.  that's a lot cleaner
(4,839 Views)
