How to reset counter from DAQ
I have a system such as X and Y coordinates, and during displacement my counter will be increase, but when this system arrives in specific coordinates, It will need to reset the counter (Equal Zero) to say this will be zero point.
Attached has a picture to show how I read pulse form DAQ.
(4,000 Views)
Hi LVelozo,
what kind of hardware do you use?
- You can always store certain coordinates in a shift register and use this as "origin". When reading new counter values you just subtract the "origin" similar to some "zeroing of offset" feature…
-  Depending on the counter hardware they could support some reset feature. But all of them can be set to zero by stopping and restarting the DAQmx task…
(3,997 Views)
Hi GerdW,
First thank you for your help.
I am using NI CompactDAQ 9178 with NI9421 to counter.
I like the ideia to use a shift register, so I will have such as "Offset". Could you send any example with shift register to store coordinates.
I appreciated a lot.
LVelozo.
(3,986 Views)
Accepted by topic author LVelozo
Hi LVelozo,
you really should know how to use shift registers!
(3,980 Views)
