How to resize a troublesome array
I am still struggling with one last thing, how do I get the milisecond timer / bench mark for the iteration of the forloop on the end of each row? In the position were it is input to the data stream in the attached vi all I get is a final value printed on the end of each row. But it should be incrementing.
If I add the milisecond timer, format_into_string and build_array before the concatenating tunnel in the forloop the milisecond timer data is incrementing but gets printed in an extra column between each register read. And I am concerned that the registers are just copies of the first reading. But There doesnt seem anywhere else to indroduce that data to the data stream.
Example of data produced by the attached vi
Data 1, data 2, data 3,        data 4,   data 5,     milisec
40806,48646,-40.156933,3.459666,0.032125,8.86860s
Example of data produced if the input is before the concatenating tunnel in the for loop.
Data 1, data 2, milisec 1, data 3,    milisec 2,  data 4,    milisec 3, data 5,     milisec 4
4802,48649,8.84844s,-40.151413,9.08847s,3.459666,9.32840s,0.032125,9.56936s
Message 21 of 24
(601 Views)
Accepted by topic author EdHarris
You give two examples of what you apparently don't want, but no example of what you actually want.
You still have that silly FOR loop where you write the exact same thing N times! Delete that little FOR loop! To get the data from all iterations into the file, the output tunnel of the while loop needs to be indexing (currently it is "last value", so you only get the data from the last iteration and all data from earlier iterations are irreversibly lost!).
Did you even study my VI?
Message 22 of 24
(591 Views)
Thanks,  I deleted the silly forloop and changed the tunnel to indexing which gave me only one line of readings. So I moved the write vi into the while loop which works perfectly. I did study your examples, thanks, and am now understanding indexing and output of loops much better.  It seems the vi became simpler and simpler the closer is got to a solution.
Message 23 of 24
(570 Views)
You don't need any wait in the reading For-loop and if it's different Visa resources you can parallellize that loop. Now it's starting to loop like a correct little program. 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 24 of 24
(556 Views)
