How to resize array index field in LV6.1?
Hiya
If I create an array control on the front panel, the size of the array index fields seems to be fixed, which is a pain if you have an array with more than 1000 elements (because the field is not wide enough to display the index).
Is there a way to resize the field, or is this yet another thing to put on the wish list?
Cheers
Joolz
(2,780 Views)
Place your cursor in front of a border of the index field so that you get the same thing as shown on the image. Place then your cursor on the top left corner until your cursor becomes a corner. You can now left click and make the fiel bigger.
Hope this helps !
Julien
(2,780 Views)
Thanks! - I'd tried left and right clicking and hovering over the field, but I hadn't waited long enough - I'm too impatient!
Cheers
Joolz
(2,780 Views)
