How to retrieve the label of a menu ring when i know its Value ?
I have defined a menu ring with 5 items:
Label
(2,603 Views)
Hi.
You need to create a property node of the menu ring, and index the array that you obtain with the value of the menu ring, as shown in the attached picture.
Hope this helps.
Alejandro
(2,589 Views)
thanks a lot it is perfect.
(2,572 Views)
