How to rotate a picture or pixmap?
hello all,
I read from jpeg files some pictures and display it in a picture control.
I would like to rotate (90°,180°,270°) or miror the content of this picture control.
Could someone give me a hint or a solution of how to do that?
I did not find any property or invoke node to do that. I think that I have to convert to a pixmap and manipulate the array but I don't know how.
I use LV 8.0 Pro.
Thanks in advance.
Message 1 of 8
(18,167 Views)
I wrote a program to rotate images from JPEG files. It obtains pixmap and rotates the array. When I tried to save it for 8.0, some functions were not available in that version so I can't send it to you. I cleaned it up a bit. It is not quite the same as my 8.2 version but it works. It is rather slow on large files: a 7.3 megapixel image takes tens of seconds to rotate. I have not worked much on trying to optimize it yet.
Lynn
Message 2 of 8
(18,157 Views)
I sucessfully did some transformation but the 180° is still missing, could someone give me a hint (algorithm)?
See attached VI
Message 3 of 8
(18,156 Views)
thanks johnsold, our messages were posted at the same time.
Anyway I can't open you VI (I have an error because your VI is made with LV 8.2).
Message 4 of 8
(18,154 Views)
Can't you just run your rotate 90 degree code twice?
Message 5 of 8
(18,150 Views)
On a side-note: if you want to ratate by arbitrary angles, you could do something like in the example I posted long ago:
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=748#M748
Message 6 of 8
(18,147 Views)
To rotate by 180, I would do it "in place". Probably cheaper than 2 succesive 90degree rotations.
See if this works for you:
Message Edited by altenbach on 03-15-2007 10:28 AM
Message 7 of 8
(18,149 Views)
thanks altenbach, works correctly and is more efficient than 2 times 90° rotation.
Could someone tell me if my code for rotating 90° is correct or if there is something more efficient to do?
Message 8 of 8
(18,126 Views)
