How to run a numeric limit test without a VI?
I have a measurement that was stored as a variable in a previous step and now I need to put it in a numeric limit test. How do I do this without a VI?
(2,839 Views)
Hi mshask,
you really need to explain why you want to do something "without a VI" when you ask in a LabVIEW forum…
Where did you store your signal data? (LabVIEW uses a different conecpt of "variables"!)
Are you using a state machine when you refer to "steps"?
Do you want to apply an InRangeAndCoerce function on your data?
(2,823 Views)
What do you mean by "numeric limit test" ??
(2,817 Views)
Maybe limiting the number of people responding by not including any details?  😉
Bill
CLD
(Mid-Level minion.)
(2,806 Views)
Accepted by wiebe@CARYA
This question was double posted to the LabVIEW and TestStand forums.
The solution can be found here: Re: Numeric limit test without a VI?
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(2,744 Views)
