How to run a vi by referencing in event structure
Hi
I searched for an example in Event structure. I just modified that but i am getting error(error code :1 )message when i run the program.
could anyone give suggestions why is it so.
I have attached the example program and my modified program
Message 1 of 11
(3,570 Views)
Can you post for 8.0 version?
Message 2 of 11
(3,561 Views)
Thansk muks
I change dto V8
Message 3 of 11
(3,557 Views)
[Edit: Sorry just a minute late. Even not able to remove the attachments. Its throwing some exception error.]
Sorry, your request failed. A notification has been sent to the development team to investigate.
Exception ID: 3A98D61C
Please click the Back button on your browser.
Message Edited by mathan on 06-27-2008 06:34 AM
Message Edited by mathan on 06-27-2008 06:38 AM
Message 4 of 11
(3,556 Views)
Hi Veeru,
In your Untitled 10.vi, you need to wire the Path directly to the Open VI Reference or just give the name of the VI in a string to the Build Path primitive that comes from the Strip Path primitive from the Current VI Path primitive.
By your (wrong) method, you are giving a doudle path [Not A Path] to the Open VI Reference, thats why the error 1 comes out.
This path [D:\Documents and Settings\parthasarathi.v\Desktop] build up with this path [D:\Documents and Settings\parthasarathi.v\Desktop\A.vi] to make the wrong path [Not A Path].
It actually should be D:\Documents and Settings\parthasarathi.v\Desktop >> Build Path >> A.vi, thats it.
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 11
(3,540 Views)
Moreover, put a seperate event for your Stop button. Or, wire a value other than -1 to the Timeout terminal.
Else, your VI is stoppable only thro' the Abort button of LabVIEW.
Message 6 of 11
(3,537 Views)
Excellent partha,thanks very much.
Message 7 of 11
(3,532 Views)
one more question,
How to refer the path of VI to build path
Message 8 of 11
(3,511 Views)
Sorry i got it
I made a simple mistake so i got an error,thats the reason i have posted this question
Message 9 of 11
(3,503 Views)
In the same program i just modified,i am getting an error message
For ex: From ring if i select the option,a dialog box appears,if i click yes the program works fine and if i click No i am getting error message.
I think its because i am using the FPopen node.
Pls anyone suggest me why i am getting error.
Message 10 of 11
(3,480 Views)
