Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to run a vi from Java application?
Gaurav
Member
01-03-2003
01:03 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am passing data to a vi from my java swing application using data socket bean but I have to manually open and run the vi. How can I programatically open and run the vi from my java application without using ActiveX automation server?
0
Kudos
Message
1
of 2
(2,964 Views)
Reply
Re: How to run a vi from Java application?
JeanPierre
Active Participant
01-09-2003
11:32 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I don't know Java but if you can issue a shell command then you can run the VI with the command line:
\labview.exe" "
You have to set the VI to "Run when opened". The VI will run each time the command is issued, even if the VI is already opened.
LabVIEW, C'est
La
b
VIE
W
0
Kudos
Message
2
of 2
(2,964 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
