How to run command line in LABVIEW 7.1
Dear Sir/Madam,
I want to execute such as command like this:
c:\data\rename aa.txt aa.hex
In LABVIEW 7.1, how do we implement this command. I really appreciate your help on this matter.
Xia
Message 1 of 11
(8,478 Views)
Use the sys exec function.  In LV 7.1 it is in the Communications palette.
paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 11
(8,472 Views)
I was assuming this was a command line exe for renaming?
Paul Falkenstein
Message 3 of 11
(8,469 Views)
Thanks for your message. I have tried sys exe in communication palatte. But it gives me error. I am not sure what is wrong.
Actually, in windows environment, I click the "Start" Button and run "cmd". Dos environment opens and then use the command Rename test.txt test.hex
I appreciate more help on this matter.
Message 4 of 11
(8,461 Views)
Message 5 of 11
(8,459 Views)
yes.
Message 6 of 11
(8,458 Views)
what error do you get?  look at the error cluster to see this.
Paul Falkenstein
Message 7 of 11
(8,450 Views)
Can you send me the program you write so that I can compare?
Thank you!
Message 8 of 11
(8,444 Views)
I realize this isn't a direct answer to your question, but if you are trying to rename a file, why don't you use the move function in the Advanced File Functions palette?
Message 9 of 11
(8,443 Views)
You may need to use the following coomand line for system exec:
cmd.exe /c c:\data\rename aa.txt aa.hex
Message 10 of 11
(8,440 Views)
